1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: forcing binary output value at initialization
To: [email protected]
Date: Fri, 21 Apr 2000 19:20:37 -0600 (MDT)
Dear Andrew, Ned and William
	Thanks very much for your quick responses, and on Good Friday at
that.
	I already observed the nice bumpless reboot feature of the
XVME-240 -- if I do a "soft" restart (like if you type cntl-X or hit the
"abort" button), then the output values of the XVME-240 do not change
while the EPICS system restarts.  This is great, and I wouldn't have a
problem if "soft" reboots were the only thing that ever happened...
	Unfortunately, I have to anticipate the occasional "hard" reboot
(like if the processor hangs and you have to do a power cycle or
press the "reset" button).  During a "hard" reboot, the XVME-240 is
cleared, and so I need for it to come to a failsafe setting when
everything is restarted.  In my system, the failsafe position will be "all
outputs high" -- hence I am trying to find a way to force that condition
when the database starts up.
	Of course, it would be nice to have the best of BOTH worlds:
bumpless reboot during a "soft" reset, and failsafe condition after a
"hard" reset.  That requires a method to know what kind of reboot is going
on.
	Ned's suggestion to execute explicit commands (dbpf "mybo","1") at
startup is a possibility for me, since I have automated database creation
scripts.
	Hmmm... Another idea might be for me to have my very own
definition of the bo record, with initial value "1" instead of "0".  I
think that would allow me to have the "best of both worlds" as described
above.  But now I am beginning to speculate, always a good time to end the
email.
						thanks,
							Steve
Stephen Pate		Department of Physics		office:   505-646-2135
			Box 30001, Dept. 3D		dept:     505-646-3831
			New Mexico State University	fax:      505-646-1934
[email protected]		Las Cruces NM 88003		home:     505-382-6880
Re: forcing binary output value at initialization Andrew Johnson
forcing binary output value at initialization pate
Prev: Re: forcing binary output value at initialization William Lupton
Next: Re: forcing binary output value at initialization Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: forcing binary output value at initialization Andrew Johnson
Next: Re: forcing binary output value at initialization Andrew Johnson
