1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: telnet based device support
To: Jim Thomas <[email protected]>
Cc: [email protected]
Date: Thu, 30 Mar 2000 07:14:47 -0700
Hi Jim,
I recall that a terminal server driver and device support was written at
Gemini.
In a tech-talk posting back in 1998, Maren Purves wrote
We're using drvAscii/drvSerial with Bret Goodrich's tnetdev, running
our serial line devices on a terminal server, over Ethernet. This
works even to the point that some time ago we had the serial line
devices at the telescope with the VME crate in Hilo.
This might help you.
Jim Thomas wrote:
> Has anyone written a drvTelnet that provides a generic interface to devices
> which provide a telnet connection for ASCII commands?  We have the new Galil
> DMC-2180 that sits out on the network.  Since just opening a socket on port
> 23 does work, has anyone done device support for anything outside of VME
> and serial devices?  I don't see anything similar in the distribution or in
> the "supported" devices list at APS.
Aloha,
	Peregrine
Peregrine M. McGehee	[email protected]	(505) 667-3273
LANL Telescope Engineering, Sloan Digital Sky Survey
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
telnet based device support Jim Thomas
Prev: Re: EPICS question: upper/lower voltage check Marty Kraimer
Next: Re: All outlinks not created equal?? Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: telnet based device support Jim Thomas
Next: poptions argument in dbGetLink routine. Noboru Yamamoto
