1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: All outlinks not created equal??
To: Tim Mooney <[email protected]>
Cc: [email protected], [email protected]
Date: Wed, 29 Mar 2000 19:03:20 -0500
Tim Mooney wrote:
> One possibility is that dynamic links are implemented with channel-access
> calls, while standard links may be database links or channel-access links.
> With database links, it's the link's job to decide whether or not processing
> is to occur.  If you want to process a record with a link, the link attribute
> must be PP.  (Exception: if the field you're writing to is inherently PP, then
> the link attribute CA will also cause processing.)
The link is PP.  It still doesn't work.
Besides, shouldn't writing directly to the PROC field make the question of
whether the link decides to process the record irrelevant ?
Brian McAllister                 Application Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
Re: All outlinks not created equal?? Tim Mooney
Prev: Re: All outlinks not created equal?? Tim Mooney
Next: EPICS question: upper/lower voltage check Johann M. Heuser
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: All outlinks not created equal?? Ned Arnold
