1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM widgets
To: tech-talk <[email protected]>
Date: Wed, 29 Mar 2000 13:12:26 -0600
Here's my plug for using Python for specialized tasks instead of Tcl/Tk,
Java, or Perl.  We have developed a Python module that implements channel
access.  Our GUI interfaces use Tk.  There are other window managers
available.  For increased speed you can code in C/C++ and then wrap the
code for use in Python.
Geoff
Ken Evans wrote:
>  > I'm Isabelle YAO and I work for the CEA-Saclay.
>  > I use EPICS R3.13.0.beta11, with a SOLARIS workstation.
>  > I'm in charge of the design of a vacuum synoptic using MEDM
>  > 2.3.5a.
>  > I would like to know if vacuum objects, like pumps, gauges,
>  > valves, already exist.
>  > Another question : is it possible to upgrade the library of
>  > MEDM by creating new objects (like magnets, DCCT, or
>  > insertion devices like Faraday cup, profilers, ...) ?
>      2.3.5a is the latest released version of the original MEDM, which
> was developed and continues to be developed at Argonne.  What I say
> here applies to this MEDM, not the European version, with which I have
> no experience.  Thomas has already responded in regard to the European
> version.  Also it should be noted that MEDM 2.3.6 has been released in
> beta and is nearly ready for release.  There are a lot of new
> features.
>     MEDM consists of a small number of objects.  It is not easy to add
> new objects because the code was not designed that way, unfortunately.
> There is no intention of adding new objects, especially large numbers
> of them.
>     So you have two choices.  (1) Make screens using the existing
> objects, or (2) write other applications to do more specialized tasks.
> We do both here.
>      (1) Most of the vacuum control here at the APS is done with MEDM
> screens using the existing objects.  Some of these screens are pretty
> complicated.  It might be worth a trip here to see what has been done
> and get samples, etc.  It's hard to communicate about GUI objects via
> the internet, and it could save a lot of your time and give you ideas.
>       Be assured that a great variety of screens can be designed with
> the small number of objects.  They are more than sufficient to control
> the APS, which is a reasonably large project.  We have literally
> thousands of MEDM screens, as do other sites like Jefferson Lab.  Some
> of these are pretty sophisticated.
>      (2) MEDM cannot be all things to all people.  The first
> consideration of MEDM is that it be stable and reliable.  This is not
> commensurate with feature bloat.  To let MEDM do what it does well, it
> is better to make separate applications for specialized and
> complicated tasks.  These are called Application Programs here and
> probably elsewhere.  At Argonne, we have done this through things like
> Tcl/Tk scripts, IDL, and C/C++ programs.  Mostly we have used Tcl/Tk
> to make small scripts that do specific tasks.  It is relatively easy
> to make a nice GUI interface with Tk.  We have a library of basic
> objects like the main menu bar, entry boxes, etc.  One feature of the
> objects in our library is that they have help built in, so it is hard
> not to program it.  That is, the user can get help on each entry box,
> etc. by clicking on it.  (This is something programmers tend to not
> provide well.)  For more information on the library and what we have
> done you could contact Michael Borland ([email protected]).
>      Nowdays, Perl or Java would be candidates for these types of
> programs, but Tcl/Tk has worked well.
>      The major advantage of writing Application Programs is that *you*
> have control and don't have to rely on someone far away to fix things
> for you.  You can do just what you want.
>      People with just basic programming skills can learn and use
> Tcl/Tk.  However, there are some applications that do require
> performance.  These are best written in C/C++.  If they need a GUI
> interface, it probably best implemented in Motif.  Programming Motif
> requires more than basic programming skills and far more code to do
> the same thing than in Tcl/Tk, but there are usually people around who
> are competent to do this.  Also there are several programs of this
> nature already written as EPICS Extensions.  One example is the Array
> Display Tool (ADT).  It is designed to handle arrays of PVs, such as
> BPM readings around a ring.  Or, vacuum readings around a ring.  It
> was originally written after discovering that MEDM could not really do
> that for several hundred BPMs to say nothing of having all the
> features that ADT has.  It and the other EPICS Extensions are
> available through the regular EPICS distribution channels.
>      At the APS the tendency has been to write C/C++ programs only
> when absolutely necessary.  The bulk of the Application Programs are
> Tcl/Tk, and this has worked out well.
>      I should say that part of the need for advanced programs has been
> supplied by the SDDS toolkit, also available as an EPICS Extension.
> This is a topic in itself, and you should refer to the EPICS
> Documentation or contact Mike Borland for more information.  These
> tools are more used for analysis than control.
>      Finally, in light of what Thomas said, I will say that MEDM 2.3.6
> has the ability to replace all or parts of the screen based on the
> values of a CALC expression involving up to five PVs.  These parts can
> be read from other ADL files.  This is a new feature of the MEDM
> Composite object and seems to be similar to what Thomas described.
> There are also animated GIFs where the frame displayed depends on a
> similar type CALC expression.  You could use these to display the
> state of a vacuum valve pictorially.  There is even a new Epics
> Extension called Simple GIF Animator (SGA) to help make the animated
> GIFs.  My advice, however, is to follow the KISS principle and keep it
> simple (and hence manageable and reliable).
>              -Ken
Re: MEDM widgets Robert Soliday
Re: MEDM widgets Ken Evans
Prev: Re: MEDM widgets Ken Evans
Next: Re: MEDM widgets Robert Soliday
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
