1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Compiling EPICS
To: [email protected], [email protected]
Date: Thu, 16 Mar 2000 09:35:28 +0000 (GMT)
Hi Robert,
Did you define INCLUDE_SHOW_ROUTINES in your vxWorks configAll.h ?
if not, rebuild vxWorks might fix your problem.
Matthieu
> Date: Thu, 16 Mar 2000 03:32:14 -0500 (EST)
> From: Robert Willson <[email protected]>
> Subject: Compiling EPICS
> I downloaded the most recent version of EPICS, R3.13.2, and attempted to
> compile it on Solaris 2.7 with GNU make version 3.77 and GNU gcc version
> 2.95.2.  The cross-compiler to an MV167 architecture I used was cc68k,
> version 2.6-95q2.  Everything compiled OK with the obvious changes to
> the CONFIG files, albeit with a few warnings.
> When I try to load iocCore, I get
> -> ld < iocCore
> undefined symbol: _semShow
> ld error: error reading file (errno = 0x1c0001).
> value = 0 = 0x0
> I'm hoping there is something very simple I've missed, as I am unable to
> understand how I could get this error.
> Thanks,
> Robert Willson
> [email protected]
 Matthieu Bec                       Isaac Newton Group
 tel  : +34 922 425427              Apartado de Correos 321
 fax  : +34 922 425429              38780 Santa Cruz de La Palma
 url  : www.ing.iac.es/~mdcb        Canary Islands, Spain
Prev: Compiling EPICS Robert Willson
Next: Re: IOC Performance numbers Richard Dickson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Joerger 100MHz VWG Korhonen Timo
