1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM
To: "Burkhard W. Kolb" <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Mon, 06 Mar 2000 07:03:55 -0800 (PST)
I don't have a 162 manual so I don't know why you would need to change the
access mode from sup-data to usr-data.  Also, does the 162 support D32
acceses on the back-plane (maybe it is only D16, I've seen some boards
that only do D16).  Sorry I can't help more.  Perry
On Mon, 6 Mar 2000, Burkhard W. Kolb wrote:
> Hi,
> thanks for the quick reply. I tried it out on Friday, but it made no change.
> I have to read the 162 manual more carefully. Don't I have to change in the
> drvSiam.c the line
> 	status = sysBusToLocalAdrs(VME_AM_STD_SUP_DATA,(char *)base_addr,...
> also then to ...VME_AM_STD_USR_DATA...?
> To the Epics/VxWorks community:
> Did anybody do this modification to the sysLib.c on the 162 for the SIAM
> or anything similar?
> 	Burkhard
Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
Prev: Re: mv162 hangs on reboot Peregrine M. McGehee
Next: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
