1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM
To: "Burkhard W. Kolb" <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Fri, 03 Mar 2000 08:08:38 -0800 (PST)
For the mv167 we needed to make a change in sysLib.c (which configures the
VMEchip2) to allow for A24/D32 accesses.  sysLib.c is in
vxworks/target/config/mv167, I assume that there is a similar file for the
mv162 though we do not use that board.  In sysLib.c there is a section (in
the mv166/67/77 seriers) where this is being controlled, the original file
has:
    /* set VMEbus std access and enable map */
    *VMECHIP2_LBSAR2            = 0xf0fff000;
    *VMECHIP2_LBSAR             |= LBSAR2_AM_STD_USR_DATA |
                                   LBSAR2_D16;
we modified this to be:
    *VMECHIP2_LBSAR             &= ~LBSAR2_D16; /* for SIAM 7/31/97 */
                                   LBSAR2_D32;
    *VMECHIP2_LBTVCR            |= LBTVCR_EN2;
As you can see, we did this to support the SIAM.  Hope this helps you.
Perry
On Fri, 3 Mar 2000, Burkhard W. Kolb wrote:
> Hi,
> I have a problem setting up a 162 cpu to work with the SIAM (Bira 7550) module.
> This module allows A24 access only. It has an Status register (32 bits)
> at its
> base address and then various 16bit registers at +4... addresses. As far
> as I
> understand the BSP for the 162 (in syslib.c) the VME access in A24 mode is
> word (16 bit) only. When the code accesses the statusregister with a long
> pointer the VMEchip2 is supposed to break this into 2 cycles of 16 bit and
> then fit the longword together from the two pieces, right?
> When I print out the status register contents I get 0xcd55ffff. On a VMEbus
> display I see the 0xffff and the last address being 0x00300002. But the word
> 0xcd55 is the (fixed) contents of the ID register of the module, at address
> 0x00300004.
>  Something wrong in the way the registers are setup for the VMEchip2?
> Burkhard Kolb
> GSI Darmstadt
> HADES detector
Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
Prev: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
Next: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM saa
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problem with MVME162 and A24/D32 or D16 access to SIAM Burkhard W. Kolb
