1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: in search of: high current binary output device
Cc: [email protected], [email protected]
Date: Sat, 26 Feb 2000 15:19:42 -0800
I have written device support for both the Greenspring IP-Digital24
24 bit digital I/O module and the Greenspring IP-Driver40 module.
The IP module drivers are build on Andrew Johnson Industry Pack Carrier
support.  More information on this can be found at
http://www.aps.anl.gov/asd/people/anj/ipac.
I think the IP-DRIVER40 might be the kind thing for your application
since
it has open collector outputs for driving things like relays.  I can
tar up what I have and send it to you if you are interested.
Len
Mark Rivers wrote:
> >       I need to find a high current (15 mA at +5V) binary output device
> > to drive a relay.  Typical TTL output devices, like the XYCOM XVME-240, do
> > not provide enough current at 5V.
> >       If anybody knows of such a device, and if there is existing EPICS
> > support for it, that would be excellent.
> The Greenspring IP-Unidig module is a 24-bit digital I/O  Industry Pack module
> capable of sinking up to 64mA per bit at 5V. It has on-board 5V pullup supply
> and open-collector outputs. I have written EPICS device support for it, using
> the Message Passing Facility.
> Mark Rivers
____________________________________________________
Leonard J. Reder
Jet Propulsion Laboratory
Interferometry Systems and Technology Section 383
Email: [email protected]
Phone (Voice): 818-354-3639
RE: in search of: high current binary output device Mark Rivers
Prev: RE: in search of: high current binary output device Mark Rivers
Next: building extensions Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
