1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: native type of gdd object
To: Jeff Hill <[email protected]>
Cc: [email protected], Kay Kasemir <[email protected]>
Date: Wed, 23 Feb 2000 14:03:56 -0600
It was it. In fact I tried that casPV::bestExternalType () and it didn't
work as it suppose to.
And reason for that was that this function must be defined as const, and in
my case it wasn't, so it
wasn't overloaded properly. May be it will be interesting for others ..
Vladimir
----- Original Message -----
To: Vladimir Sirotenko <[email protected]>; <[email protected]>
Sent: Wednesday, February 23, 2000 11:54 AM
Subject: RE: native type of gdd object
> Vladimir,
> > Could someone advise me please how to control the native type of PV
created
> > in portable CA server
> > with use of  gdd library ( pVV =  new gddScalar(gddAppType_value,
> > aitEnumFloat32); )
> > I mean native type which can be asked using  ca_field_type() function ..
> > I have two servers running with the same PV creation, but one gives
native
> > type = 2 (float) and
> > another gives 0 (string). Is there any way to change native type from 0
to
> > 2, for example? Thanks,
> The virtual function "casPV::bestExternalType ()" determines the native
data type
> as seen by the client application. The base implementation of this virtual
> function returns type string, but you can override this behavior by
implementing a
> replacement in your derived class.
> Jeff
RE: native type of gdd object Jeff Hill
Prev: Switching from a 167 to a 162 Dennis M. Reichhold
Next: Re: Switching from a 167 to a 162 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: native type of gdd object Jeff Hill
Next: Re: native type of gdd object Kay Kasemir
