Geoff,
The second part of the message which is varying between "No such file or directory",
and "Address already in use" is generated directly from the socket library errno
in the client process. These messages directly map to socket library error numbers
2 and 48 respectively. Sometimes there are problems because CA has accessed
some other function in the C run time library in-between the spot in the source
code where the problem occurred and where CA reports the error, and therefore
the errno variable might be overwritten. In this situation I don't see this mechanism
in play. Without knowing more about which operating system you are running on or
what version of EPICS is running it is difficult to comment further.
Jeff
PS: I have attached the source code that is involved.
status = connect(
piiu->sock_chan,
&pNode->destAddr.sa,
sizeof(pNode->destAddr.sa));
if (status == 0) {
break;
errnoCpy = SOCKERRNO;
if (errnoCpy==SOCK_EISCONN) {
* called connect after we are already connected
* (this appears to be how they provide
* connect completion notification)
break;
else if (
errnoCpy==SOCK_EINPROGRESS ||
errnoCpy==SOCK_EWOULDBLOCK /* for WINSOCK */
* The socket is non-blocking and a
* connection attempt has been initiated,
* but not completed.
UNLOCK;
return;
else if (errnoCpy==SOCK_EALREADY) {
UNLOCK;
return;
#ifdef _WIN32
* including this with vxWorks appears to
* cause trouble
else if (errnoCpy==SOCK_EINVAL) { /* a SOCK_EALREADY alias used by early WINSOCK */
UNLOCK;
return;
#endif
else if(errnoCpy==SOCK_EINTR) {
* restart the system call if interrupted
continue;
else {
TAG_CONN_DOWN(piiu);
UNLOCK;
ca_printf(
"CAC: Unable to connect port %d on \"%s\" because %d=\"%s\"\n",
ntohs(pNode->destAddr.in.sin_port),
piiu->host_name_str, errnoCpy,
SOCKERRSTR);
return;
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Tuesday, February 22, 2000 12:51 PM
> To: tech-talk
> Subject: CA error #2 and #48
> Hi,
> Would someone please explain when CA feels it should spit out these
> error messages.
> CAC: Unable to connect port 5064 on "d0olctl03.fnal.gov:5064" because
> 2="No such file or directory"
> CA.Client.Diagnostic..............................................
> Message: "Network connection lost"
> Severity: "Warning" Context: "d0olctl03.fnal.gov:5064"
> Source File: ../iocinf.c Line Number: 1479
> 48="Address already in use"
> Thanks
> Geoff
- Re: CA error #2 and #48 Geoff Savage
- CA error #2 and #48 Geoff Savage
Re: Problems with messages... Maren Purves
Re: Problems with messages... Pete R. Jemian
<2000>
<2000>
