1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: disabling telnet and rlogin
To: [email protected]
Date: Tue, 22 Feb 2000 08:55:04 -0800
Title: Re: disabling telnet and rlogin
At 10:18 AM -0600 2000/02/22, Andrew Johnson wrote:
"Porter, Rodney" wrote:
> Following up on your security talk at APS, I was wondering if there is a
> standard way to disable telnet and rlogin.  If not could one be made?
You can inspect the INCLUDE_CONFIGURATION_5_2 macro, which is just
a bunch of #defines, and pick what you want, leaving out telnet and
rlogin.  Just move the onces you do want from the grouping after
#ifdef FALSE to just above it.
By the way, I leave them in, because they are useful to me; further,
I assume VxWorks is extremeley vulnerable, so to get some real security,
I:
 - put my IOCs on a hidden subnet, for example, using IP masquerading
   on one of my dual-homed servers.  This really hides them from the
   Internet (and is good practice for your console Unix/NT machines as well--
   they can still see "out".);
 - do not give the IOCs a DEFAULT route; at most, give them single-host
   routes to special hosts not on the hidden subnet.  They will not reply
   to any packet not on their own LAN (which would not occur if using
   the IP masquerading technique, of course).  You can still access them
   by using ssh once to your above server; then rlogin or via you serial
   port acess method;
 - change the default password and login supplied by WRS.  Do this by
   looking further down in configAll.h;
 - finally, VxWorks is pretty obscure; I still forget to put quotes
   around the arguments to cd and ls.
_____________________________________________________________________
Stephen A. Lewis                        | [email protected]
Mail Stop 71-259                        | http://www.lbl.gov/~salewis
Lawrence Berkeley National Laboratory   | Tel: +1.510.486.7702
Berkeley, CA 94720    USA               | FAX: +1.510.486.4544
RE: disabling telnet and rlogin Jeff Hill
disabling telnet and rlogin Porter, Rodney
Re: disabling telnet and rlogin Andrew Johnson
Prev: Re: disabling telnet and rlogin Andrew Johnson
Next: RE: disabling telnet and rlogin Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
