1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: disabling telnet and rlogin
To: "Porter, Rodney" <[email protected]>
Cc: [email protected]
Date: Tue, 22 Feb 2000 10:18:04 -0600
"Porter, Rodney" wrote:
> Following up on your security talk at APS, I was wondering if there is a
> standard way to disable telnet and rlogin.  If not could one be made?
Probably the simplest way is to add the following two lines to your
startup script:
	td tTelnetd
	td tRlogind
On my mv167 this frees up about 21k of RAM from the two task stacks which
loginUserDelete doesn't do, and I guess it will also be marginally more
secure.
> These functions are not currently defined independently (as INCLUDE_RLOGIN
> and INCLUDE_TELNET), but are included with the definition
> INCLUDE_CONFIGURATION_5_2 in target/config/all/configAll.h, which is
> expanded in target/src/config/usrDepend.c.
You could replace that INCLUDE_CONFIGURATION_5_2 with the individual
expansions in your configAll.h if you want to change this and save even
more space by not loading the rlogind & telnetd code at all.  I may do
this for the Tornado 2.0 BSPs, although the old method still works in that
version.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: disabling telnet and rlogin Steve Lewis
disabling telnet and rlogin Porter, Rodney
Prev: disabling telnet and rlogin Porter, Rodney
Next: Re: disabling telnet and rlogin Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
