1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: monitors for arrays
To: [email protected]
Date: Fri, 11 Feb 2000 11:22:05 -0700
Brian,
I ran into this same problem on one of my own custom records.  The trick
is that the 2nd parameter of db_post_events should be the address of the
*data* (usually this is the same as the address of the field, but not for
SPC_DBADDR fields).
Hope this helps.
Eric Bj.
>I'm trying to get monitors for arrays in a custom record to work.
>Here's a piece of the monitor() function:
>    monitor_mask = recGblResetAlarms(pbpm);
>    monitor_mask |= (DBE_VALUE | DBE_LOG);
>    db_post_events(pbpm, &pbpm->nscp, monitor_mask);
>    if (pbpm->nscp > 0) {
>	db_post_events(pbpm, &pbpm->xscp, monitor_mask);
>Here are the field definitions:
>	field(NSCP,DBF_SHORT) {
>		prompt("Number of Scope Samples")
>		special(SPC_NOMOD)
>		interest(3)
>	field(XSCP,DBF_NOACCESS) {
>		prompt("X Scope Data")
>		special(SPC_DBADDR)
>		interest(3)
>		extra("uint8_t * 	xscp")
>Monitors on NSCP work just fine.  Monitors on XSCP only get called once.
>What am I missing ?
Eric Bjorklund				Voice: 505-667-6031
Los Alamos National Laboratory		Email: [email protected]
LANSCE-6 MS H828
PO Box 1663
Los Alamos, NM 87545
"Try not to sweat the petty things.
 And for sure don't pet the sweaty things."
Prev: monitors for arrays Brian McAllister
Next: RE: DEC Threads Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
