1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DeviceNet driver
To: [email protected] (Ron Battle), [email protected]
Date: Fri, 11 Feb 2000 08:44:29 -0800
At 03:23 PM 2/9/00 -0500, Ron Battle wrote:
>Has anyone developed an EPICS DeviceNet driver for the SST 5136-DN-VME card?
>We have developed a host application that uses the VME card as a master to
>communicate with a DeviceNet Flex I/O adapter. The host application
>configures the modules on DeviceNet and starts polling the Flex I/O
>adapter. However, we could use help interfacing this card to EPICS.
We are working on a similar project.  For a deviceNet interface we're
using the "DeviceNET-IP" IP card from Greenspring.  The first device
we've got to get going is an AB 1747-SDN scannerwhich is supposed to
enable us to "talk to" an AB PLC.
We're not quite as far along as you are - we got blindsided by the
configuration of the scanner as provided by the vendor of the system,
and then the system (power supply for a superconducting magnet) got
shipped off to the magnet vendor.
Perhaps we can work out the details of the epics interface together.
-bill
DeviceNet driver Ron Battle
Prev: Re: Greenspring Octal serial IP device/driver support Andrew Johnson
Next: monitors for arrays Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: DeviceNet driver Ron Battle
Next: support for CAMAC SAM 5305 Burkhard W. Kolb
