1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: support for output records
To: "Leo R. Dalesio" <[email protected]>
Cc: [email protected]
Date: Mon, 07 Feb 2000 12:40:21 +0100
Leo R. Dalesio wrote:
> I would think that a soft bo with an undefined DOL that has
> been processed at initialization should be 0 and defined. If someone
> wanted the value to be something other than 0 - they could have put
> the constant 1 in the DOL field. As some of the configuration tools
> do not define a field if it is the same value as the default, an undefined
> field should be construed as a 0. Just my opinion....
The question is, of course, relevant to output records in general.
The Release Notes to R3.13 say: "Another feature is is that it is now
possible to distinguish link constants with a value of 0 from links that
have never been given a value".
I believe that the distinction between zero ("0") and undefined ("") has
been made in order to allow undefined links to be completely ignored by
the record support in contrast to constant-zero links. Link behavior
should be consistent throughout the system and IMHO undefined is not the
same as zero.
If people want to have a zero value at init, they can either set it in
the database, or, if they insist on a different *default* behavior for
the DOL links, we (or they) can set 'initial("0")' in the record's
definition of the DOL field and everything works as expected without
changing the record support.
I'd like to know if it is the general opinion that an output record that
has been processed is defined (i.e. UDF==FALSE), even when
- no value has been put into VAL,
- DOL is undefined, and
- no readback was done by the device support.
Ben
The Notorious Neb Nesknarf
Re: support for output records Bob Dalesio
Re: VxWorks global variable device support (boRecord.c) saa
Re: VxWorks global variable device support (boRecord.c) Benjamin Franksen
Prev: Re: support for output records Bernd Schoeneburg
Next: Re: Using EPICS CA from Python Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks global variable device support (boRecord.c) Benjamin Franksen
Next: Re: support for output records Bob Dalesio
