So there are several inadequacies with output records that need to be
handled:
1) We need to be able to say - read value at initialization - but not
process
2) We need a general purpose way to reread the value fromt he hardware in
the case where there are multiple maters to the hardware. This opens up to
several questions -
do we always read before write? If we write and find that someone else wrote
over that value - do we overwrite it? Do we provide some general idea in the
IOC that the IOC is either
A) MAster and whatever it says is enforced - finding a different value
in the PLC is an error
B) Slave - we do not do any writing in this state
C) Multi-master - we write and then read to determine the value in the
remote.
- what about passive records? Does this add a scan on remote change
to value?
3) We need to fix passive BO's that say UDF when DOL is not defined. (Did I
get this one right?)
This affects bo, mbbo, mbbo-direct, longout, and ao.
Does it relate to steppermotors?
Does it relate to algorithmic records with OUT fields?
I think it only relates to output records with device support. I also think
that we could omit the case for steppermotors (even though I said it would
be nice to be consistent.....)
What else does this need to turn into an action item?
Bob
- Re: support for output records Bernd Schoeneburg
- RE: VxWorks global variable device support Jeff Hill
Re: VxWorks global variable device support (capfast can default DOL to not set) William Lupton
Re: VxWorks global variable device support (boRecord.c) Benjamin Franksen
<2000>
<2000>
