1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: unbundled sequencer v1.9.4 is available
To: [email protected], [email protected]
Date: Thu, 3 Feb 2000 08:59:29 -1000
Dear all,
I wrote:
>> This version of the sequencer is in operational use at SLAC (the operational
>> version at Keck pre-dates the SLAC extensions). The only known problem is
>> that "td" does not reliably delete sequencers.
Rozelle wrote:
>Have you added a snl specific command that will delete sequencers.
>We really need to be able to delete sequences without bringing iocs down.
>One of the main advantages of using the sequencer is that you can
>debug it without rebooting the ioc, in contrast to debugging databases.
No, I haven't added such a command. I think that I am going to have to
look into this and come up with a fix (I certainly don't want people not
to use the new version just because of the sequencer deletion problem).
I was under the impression that "td" did not work reliably with the base
version under R3.13 either, but perhaps that is wrong?
William
Prev: Re: VxWorks global variable device support Tim Mooney
Next: Re: unbundled sequencer v1.9.4 is available Rozelle Wright
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: unbundled sequencer v1.9.4 is available Rozelle Wright
