1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: VxWorks global variable device support
To: "Nick Rees" <[email protected]>, <[email protected]>
Date: Thu, 3 Feb 2000 11:58:03 -0700
> > I don't like to have to process the output records and cause
> any resulting
> > processing just to get the current value of an output record
> after a reboot,
> > so it would be great to add the selectable readback to all
> output records
> > or add something like RINI (read at initialization) to read but
> not process.
> While we are on the subject (which has diverged somewhat from the original
> one), I have often had the similar problem caused by rebooting fieldbus
> modules but not the IOC. In this case I have occasionally wanted my output
> record to readback the new value (post-reboot) from the fieldbus module,
> rather than set it to the last EPICS value. Hence I have always felt there
> was a better way of handling this re-initialization of output records.
> I have also found the treatment of all these things a bit inconsistent -
> especially as the code resides in device, rather than record, support (and
> so is developed by a greater number of programmers). One thought I had was
> to support a read routine in device support of output records, and then
> move a bit of the logic back into the record. We could also support a
> callback when the output hardware re-inialises. I admit that this is
> difficult to make backwards compatible.
The current version of the DF1 serial protocol driver for Allen Bradley PLCs
constantly scans the output values in the PLC, and if they are changed by
some action outside the control of the IOC, then the output record is forced
to update itself, and its CA clients, via faked asynchronous record
processing
completion. I agree that it would be preferable to include a read routine in
the output record's device support entry table together with a standard
mechanism
for signaling to output records that it is a good time to reread the
current state of the hardware.
This would provides the following benefits:
1) iocInit no longer blocks for devices that are not responding on a slow
field bus
to time out, and therefore output channels will remain in UDF alarm state
after iocInit
completes until the device responds for the first time.
2) CA clients track changes in hardware output changing outside the IOC's
control
	a) changes occur from the vendor's local control panel
	b) device is powered up
	c) communication with the device is restored
Jeff
support for output records Leo R. Dalesio
Re: VxWorks global variable device support Nick Rees
Prev: Re: VxWorks global variable device support William Lupton
Next: Re: VxWorks global variable device support Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks global variable device support Nick Rees
Next: support for output records Leo R. Dalesio
