1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks global variable device support
To: [email protected] (Deb Kerstiens)
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 3 Feb 2000 18:33:38 +0100 (MET)
  > I don't like to have to process the output records and cause any resulting
  > processing just to get the current value of an output record after a reboot,
I agree. As all our fieldbus directed outputs are terminal, i.e. there is
no resulting processing, we just didn't care.
  > We might consider one additional subtlety
Just one?
  > for those of us who use STAT and/or
  > SEVR, particularly to display value with a color rule that indicates these
  > values.  If an output record had readback but was not processed, would it affect
  > STAT and/or SEVR values.  Right now I think these are usually UDF and INVALID
  > respectively until the record is processed.
Good point. As the record is defined after reading back the value,
UDF/INVALID is inappropriate. Would you think we need to have another
status that announces that the value has been read back and is valid, but
the record hasn't been processed yet? Or would that be too subtle a
difference to be signalled?
Ralph
Re: VxWorks global variable device support Deb Kerstiens
Prev: Re: VxWorks global variable device support (capfast can default DOL to not set) Rozelle Wright
Next: Re: VxWorks global variable device support Deb Kerstiens
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks global variable device support Deb Kerstiens
Next: Re: VxWorks global variable device support Nick Rees
