g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: event_handler_args
To: tech-talk@aps.anl.gov
Date: Thu, 20 Jan 2000 16:04:21 -0500
Am I correct in thinking that the DBR structure pointed to by the
event_handler_args structure returned in the callback for a monitored channel
should be treated as volatile, requiring the data in it to be copied if you
want to use it outside of the scope of the callback function ?
Brian McAllister                 Application Programmer/Beam Physicist
mcallister@mit.edu                        MIT-Bates Linear Accelerator
RE: event_handler_args Jeff Hill
Prev: ARR not Y2K ready - fix ? Brian McAllister
Next: RE: event_handler_args Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
