Maybe we could allow the operator to enable/disable force pvs.
We could add a ForcePV Button to each alarm group or channel line
for which a Force PV is defined ( similar to the Guidance and Related
Process buttons). Pressing this button would bring up the ForcePV Dialog
window which allows the operator to view/change the ForcePV settings.
This dialog could be modified to allow the operator to enable/disable
the ForcePV. The color of the button could also indicate the enabled/disabled
status.
Janet
Sue Witherspoon wrote:
> > >I'm interested in this issue, for the same sort of scenario occurred
> > >here at Jefferson Lab. It was resolved, probably not elegantly, by
> > >using the cancel mask for the FORCEPV C----- and leaving the
> > >operators the disable masks to work as expected.
> > So, does FORCEPV "reset" action only restore the flags which were set in
> > the FORCEPV mask? I was under the impression that it restored the default
> > mask (i.e. all flags of the default mask).
> It appears that you are absolutely correct...so now I'm even more
> interested in your proposals!!!!
> ______________________________________________________________
> Sue D. Witherspoon TJNAF - CEBA
> [email protected] (757) 269-7579
> If my people would Humble, Pray, Seek and Turn....2 Chron. 7:14
- Re: alarm handler question William Lupton
- Re: alarm handler question Sue Witherspoon
EPICS 3.13.2 and vxWorks 5.4 Hammonds, John
<2000>
<2000>
