g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: alarm handler question
To: tech-talk@aps.anl.gov
Date: Tue, 4 Jan 2000 08:35:19 -1000
Hi. I have an alarm handler question...
We sometimes use the FORCEPV temporarily to disable alarms. For example,
we have a vacuum error which is disabled when the telescope is slewing
(so its mask is set to --D-- during the slew and then back to its
default of ----- on completion of the slew).
Last night, the vacuum alarms were being generated spuriously, so the
operator tried to disable them. However, each time a slew completed, the
mask was set back to the default of -----, not the operator override of
--D--.
Also, although this is specific to our operational environment, the field
which indicates slew/track is actually posted every 20 seconds
regardless of whether its state changed. This means that the mask is set
back to its default every 20 seconds regardless of whether the
slew/track state actually changed (because the FORCEPV logic checks
whether the current value matches the force or reset values; it doesn't
check for a transition).
So, I am asking whether it would be reasonable to do the following:
a) allow the FORCEPV reset mask to honor any operator overrides,
b) allow the FORCEPV logic to check for transitions to the force or
   reset values
Of course, I apologise unreservedly if we are inadvertently using an old
version and these issues have already been resolved. Happy new year to
all.
William
Re: alarm handler question Sue Witherspoon
Prev: Re: Delay of Maximize Severity in OUT Links Marty Kraimer
Next: Re: alarm handler question Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
