1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA monitors...Update
To: [email protected]
Date: Thu, 9 Dec 1999 15:06:47 -0600 (CST)
Grasping at straws, I started killing MEDM displays on the control workstations. One of them
was an XY plot of beam profiles (~75 channels total @ 30Hz rate). Turning that
display on and off had almost the same effect on the stalling problem (turned
on, big problem; turned off, almost no problem).
About that time, as I was preparing to answer difinitively, "the network is
overloaded", the network sniffer was made available. Hooking it up, we found no
errors, an incredibly small number of collisions (about 0.001%), and only 10%
network utilization (peak).
Meanwhile, my little box with the LEDs that adapts between the "thin" section of
the network and the 10/100baseT hub is still showing collisions galore.
Oh, BTW, Marty or Jeff asked earlier if it was a switched network. Yes, it is. I
have three workstations, a printer, and a couple of PCs running off a
10/100baseT hub. Then there's all the iocs remaining on the old thinwire which
is attached through an adapter box to hub.
So, now the questions are:
1) Has the sniffer been sniffing something funny and lost it's mind?
2) Are the indications on the adapter box misleading?
3) Are the collisions between the thinwire and UTP parts of the net and the
sniffer can't see 'em?
4) Why has it just suddenly become so much worse?
5) Won't somebody send me an aspirin?
Thanks everybody for your help.
Garrett Rinehart
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 S. Cass Ave
Argonne, IL  60439
(630)252-6561
RE: CA monitors...Update Jeff Hill
Prev: Using GPIB with EPICS Russell Page
Next: Re: Using GPIB with EPICS Al Grippo
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Using GPIB with EPICS Al Grippo
Next: RE: CA monitors...Update Jeff Hill
