1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: mbboDirectRecord
To: EPICS Techtalk <[email protected]>
Date: Thu, 09 Dec 1999 15:23:04 +0100
Hello,
I observed a strange behavior of the mbboDirectRecord: the record
remains undefined (UDF==1), even though a correct value was put into VAL
(the hardware was written correctly either). Nevertheless, the STAT and
SEVR are both ok.
I compared the code to that of the mbboRecord. It is obvious that UDF is
not handled properly in the mbboDirect.
First, inside init_record, UDF is not set to 0 after
pdset->init_record() returns ok. BTW, init_record checks if the return
value is 2, which doesn't make sense in a record that has no conversion.
Second, inside process(), UDF is not checked and there is no call to
recGblSetSevr that sets STAT = UDF_ALARM.
I propose to correct these things for R3.13.2.
Ben
Prev: Re: I/O Intr and Asynchronouse device Marty Kraimer
Next: RE: Delays in receipt of CA monitors Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Using GPIB with EPICS Russell Page
