1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Delays in receipt of CA monitors
To: [email protected]
Date: Wed, 08 Dec 1999 08:14:01 -0700
Here at the Low Energy Demonstration Accelerator we are seeing
intermittent significant delays in the receipt of CA monitors. As these
delays are large enough to trigger a hardware protection system that
places the accelerator in a safe mode (e.g. turn the beam off) we have
spent considerable time over the past months to understand this.
We don't yet understand the root cause and are asking if anyone has seen
a similar effect. We realize that TCP is non-realtime but are concerned
since these delays can as large as 3 to 10 seconds.
Here's the context:
In order to provide prompt detection of a failure in the control system
IOCs or network at timescales shorter than the default CA timeout (30
seconds), each IOC provides a heartbeat. This heartbeat is implemented
as a calculation record scanned at .5 second that toggles between 0 and
1. On our run permit IOC we have a genSub record scanned at 1 second
that has an input CP link to that heartbeat. Thus the genSub record will
process both at 1 second intervals and when a monitor comes in from the
heartbeat. If a monitor is not received with a specific interval (1.5
seconds) we assume that there is a problem and shut down the
accelerator.
Here's what we see:
For a small subset of IOCs, and mostly from one, we see several times a
day, delays of several seconds on the receipt of a monitor. The effect
is one of the monitors being buffered, but not lost. We can also observe
this behavior by running camonitor on an IOC heartbeat channel from a
workstation.
The timestamps generated by record processing of the heartbeats are
always seen (by dbCaGetTimeStamp) at .5 second intervals.
Here's what we don't see:
We don't see dependence on IOC architecture.
We don't see correlation with long-term resource (CPU, memory, FDs)
usage on either IOC.
We don't see correlation with network traffic.
We don't see correlation on short-term CPU usage (down to 1 second
sampling) on either IOC.
We don't see delays in the heartbeat timestamps generated at the target
IOC.
Here's what we suspect:
1) Possible short term CPU loading on the target IOC by a task with a
priority less than the .5 second scan task but greater than CA or TCP.
2) Possible buffering within CA or the TCP/IP stack.
Aloha,
	Peregrine
Peregrine M. McGehee	Coordinator, Los Alamos Astrophysics
(505) 667-3273 		MS H820, LANL, Los Alamos, NM 87545
Re: Delays in receipt of CA monitors john sinclair
Re: CA LINK's not monitoring. Ron Chestnut
Prev: zombie problem at UNIX IOC Tatiana V. Salikova
Next: Re: Delays in receipt of CA monitors Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CA LINK's not monitoring. Ron Chestnut
Next: Re: Delays in receipt of CA monitors john sinclair
