1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Access Client library
To: "Eric Boucher" <[email protected]>, "Tech-Talk" <[email protected]>
Date: Mon, 29 Nov 1999 09:49:29 -0700
> Is it safe to use the channel access client library in a multi-threaded
> environment as long as only one thread calls the ca routines or is there
> other issues ?
Yes, this is safe as long as only one thread is in the library at a time.
The client library has always been 100% thread safe on vxWorks, and in
EPICS 3.14 the client library will be thread safe on all OS.
Jeff
Channel Access Client library Eric Boucher
Prev: Channel Access Client library Eric Boucher
Next: Re: Channel Access Client library Christopher A. Larrieu
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
