1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: empty channel field in medm/dm2k
To: [email protected], [email protected]
Cc: [email protected]
Date: Mon, 22 Nov 1999 11:24:35 -0600 (CST)
>      Yes, I have noticed.  It was that way when I got it.  I think it
> is a hack to avoid some kind of error, but I don't know what.  Perhaps
> it is to force CA to allocate the usual structures instead of properly
> handling the situation.  I haven't changed it on the grounds that (1)
> it (up to now) didn't seem to be causing problems and (2) "Never
> change a working code ...".  It looks like bad coding proctice, and it
> would be nice to eliminate it, even if it weren't continually calling
> CA as Noboru says.
>       Unless someone tells me it is a known trick and has a purpose, I
> will eliminate it (in the next release).
I also use this " " to replace the NULL pvname if the user
mistakenly provided a NULL string for name search to an
interactive CA client. If I remember it right this will
avaoid the problem of core dump and accidentally get
out of the interactive CA client.
Ben-chin
Re: empty channel field in medm/dm2k Christopher A. Larrieu
RE: empty channel field in medm/dm2k Jeff Hill
Prev: RE: empty channel field in medm/dm2k Jeff Hill
Next: Re: empty channel field in medm/dm2k Christopher A. Larrieu
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
