Subject: |
CA Server Library Application Survey Summary |
[email protected] (Jeff Hill) |
To: |
"EPICS-tech-talk" <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, "Kay-Uwe Kasemir" <[email protected]> |
Date: |
Thu, 16 Sep 1999 12:34:03 -0600 |
All,
Attached is a quick summary of all of the responses to the EPICS server tool
developers survey that I sent out last year. If your comments are missing
or you would like to change or add to your answer (or my summary of it),
then
please send an update.
Thanks for your responses, I would like to use them in a paper for ICALEPCS
(if you do not object).
Jeff
PS:
GDD documentation is on the WEB at APS and CA server documentation is on the
WEB at LANL (and also in the casdef.h header file).
______________________________________________
Jeffrey O. Hill E-mail [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Application of the Server Library (server side tools):
CCD Camera & Video Processing:
LANL-LEDA (Joan Sage)
APS-SRICAT (Brian Tieman)
PSI (Miroslaw Dach) (under consideration)
Motion Control:
APS-SRICAT (Brian Tieman) (under consideration)
Low Cost Interface to Serial IO:
ORNL (John Sinclair)
Gateway to Other Systems:
MIT-BATES (Coles Sibley) (gateway to facility system) (under
consideration)
SLAC-SPEAR (Harvey Rarback) (gateway to SPEAR)
SLAC-PEPII (Stephanie Allison) (gateway to PEPII)
MSU-NSCL (John A. Priller) (gateway to NSCL)
DESY (Matthias Clausen) (gateway to DOOCS and other systems)
KEKB (Noboru Yamamoto) (gateway to KEK LINAC control system)
KECK (William Lupton) (gateway to command processor system)
High Level Languages and 3rd Party Tools:
tcl_tk (Guy Jennings)
(Ned Arnold)(under consideration)
IDL LANL-LEDA (Joan Sage)
Labview LANL-LEDA (Kay Kasemir)
Directory Service:
CA Proxy (Concentrator):
ANL-APS
SLAC
BESSY
LANL-LEDA
KEK (under consideration)
KECK (William Lupton) (under consideration)
High Power RF Fault Log:
Simulator:
Modicon PLC:
MSU-NSCL (John A. Priller) (under consideration)
Operating System:
NT:
LINUX:
APS (Guy Jennings)
MAC-OS:
APS (Guy Jennings)
VMS:
HP-UX
BESSY (Ralph Lange)
Solaris
Impression of the Software:
bit to complex, but reliable - allows commercial software
to be easily integrated:
high quality, general purpose, low effort
dynamic type conversions possible in GDD rarely necessary,
deletion policy for Server Objects is overly complex,
would prefer a simple and light weight implementation
(perhaps a C++ template process variable class),
or abstract base class might be a good alternative to GDD
APS (Guy Jennings)
it was easy to implement a server side tool, but GDD is overly complex
reliable and efficient, GDD problems with large arrays has been fixed,
bugs when asynchronous IO completes after client has disconnected
(I think this has been fixed also - joh)
nothing that we don't understand so far
NMSU (Stephen Pate)
inexpensive and low effort alternative
Impression of the Documentation:
very helpful:
APS (Guy Jennings)
examples may be out of sync:
good CAS documentation:
more documentation desired, but LANL WEB Documentation
has not yet been consulted so far
Jeff
Re: security windows for EPICS Rozelle Wright
agenda for EPICS workshop Matthias Clausen
<1999>
VME Digitizers Ned Arnold
<1999>
