1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: curious OMS58 Problem / Waveform-Size-Limitation
To: Jens Eden <[email protected]>
Cc: [email protected]
Date: Wed, 15 Sep 1999 17:09:11 -0500
Jens Eden wrote:
> We tried various cards in different crates and this only happens if the
> card has base address 0xc000, even if there are no other cards in the
> crate.
> Anyone an idea, what this could be?
This may be the same address as your CPU's mailbox interrupt registers, a
clash of which might cause strange things to happen.  What is your CPU
architecture?  If it's an mv162 or mv167, check the definition of
GCSR_GROUP_ADDR in <vw>/config/<arch>/config.h which defines the high byte
of the mailbox address in A16 space - I vaguely recall that the default
for this is 0xc0, which would put processor 0's mailbox at 0xc000.  Other
CPU types may have a similar mailbox area - SM_INT_ARG2 in the same
config.h file points to this address (as long as SM_INT_TYPE is defined as
SM_INT_MAILBOX_1, the address space is given in SM_INT_ARG1).
- Andrew
Complexity comes for free, Simplicity you have to work for.
curious OMS58 Problem / Waveform-Size-Limitation Jens Eden
Prev: Tornado Tool usage. Ron Sluiter
Next: RE: curious OMS58 Problem / Waveform-Size-Limitation Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: curious OMS58 Problem / Waveform-Size-Limitation Jens Eden
