1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: SENS stack vs EPICS
To: "Bill Brown" <[email protected]>
Cc: "Alan Biocca" <[email protected]>, "EPICS-tech-talk" <[email protected]>
Date: Mon, 13 Sep 1999 09:40:29 -0600
Bill,
> A while back you wrote:
> > This is a known problem with Channel Access and the new "SENS"
> > IP kernel from WRS.  They (WRS) are defining a macro with the
> > same name as one of the fields in a data structure used throughout
> > the CA source code.
> > This problem can be avoided if the "SENS" option is not specified
> > when installing Tornado.
> Perhaps you have said more on the subject, but I couldn't find it in
> the archive.
> In order to get a version of vxWorks for the mcp750 cpu (which we're
> using in our compact PCI efforts) which will allow us to use a
> reasonable
> amount of cPCI address space, we're forced to move to vxWorks 5.4.  And
> vxw_5.4 doesn't provide an option to use the old IP stack.  "SENS" is
> the only option, AFAIK.
It turns out that this problem is worse than it initially appears.
I have already changed the 5 letter structure member name that their
macro collides with, but there is this additional problem that none
of the network interface query ioctl() stuff is working. The result is
that the EPICS_CA_AUTOT_ADDR_LIST=YES related code in Channel Access
fails. The symptoms of this are hard to miss in IOCs that are CA client's.
The effect (no beacons) on IOC's that are CA servers is more subtle.
I have a TSR open with WRS.
Jeff
> reasonable
> No doubt this is a (the?) major value-added feature of vxw_5.4 & Tornado
> 2.
> Is there a patch or some work-around available?  How horrible is it
> going
> to be to fix this?  Any suggestions besides, "Don't do that!"?
> TIA for your suggestions!
> -bill
RE: SENS stack vs EPICS Alan Biocca
Prev: Unix sequencer William Lupton
Next: RE: SENS stack vs EPICS Alan Biocca
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
