1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problems with CA in a WAN environment
To: [email protected]
Date: Thu, 09 Sep 1999 13:13:40 +0200
I have a problem with channel access in a WAN environment and would like
to ask the experts whether
they have an idea on how to trace the problem.
I have carefully checked all environment variables and timeouts and my
guess is that the messages from
the CA server do not reach the CA client (the other direction seems to
work).
On my CA server box I was setting CASDEBUG to 3.
On the client side I was using cau to retrieve an epics record
(mpia:tvGuiderY).
I tried longer timeouts but without success.
Below are the log records.
Thanks
/Stefan/
CA client:
cau> get mpia:tvGuiderY
CA servers messages:
0xce42b4 (CA UDP): CAS: Sending a message of 0 bytes
0xce42b4 (CA UDP): CAS: cast server msg of 32 bytes
0xce42b4 (CA UDP): CAS: from addr 95d928df, port cf26
0xce42b4 (CA UDP): CAS: Parsing 32(decimal) bytes
0xce42b4 (CA UDP): CAS: cmd=6 cid=0 typ=5 cnt=6 psz=16 avail=0
0xce42b4 (CA UDP): CAS:         N=1 paddr=0
0xce42b4 (CA UDP): CAS: Sending a message of 24 bytes
0xc486fc (CA client): CAS: Creating new udp client
0xc486fc (CA client): CAS: converting udp client to tcp
0xc486fc (CA client): CAS: Recieved connection request
0xc486fc (CA client): from addr 95d928df, port cd71
0xc486fc (CA client): CAS: Parsing 80(decimal) bytes
0xc486fc (CA client): CAS: cmd=20 cid=0 typ=0 cnt=0 psz=8 avail=0
0xc486fc (CA client): CAS:      N=1 paddr=0
0xc486fc (CA client): CAS: cmd=21 cid=0 typ=0 cnt=0 psz=8 avail=0
0xc486fc (CA client): CAS:      N=2 paddr=0
0xc486fc (CA client): CAS: cmd=18 cid=0 typ=0 cnt=0 psz=16 avail=6
0xc486fc (CA client): CAS:      N=3 paddr=0
0xc486fc (CA client): CAS: Sending a message of 32 bytes
0xc486fc (CA client): CAS: Parsing 16(decimal) bytes
0xc486fc (CA client): CAS: cmd=10 cid=0 typ=0 cnt=0 psz=0 avail=0
0xc486fc (CA client): CAS: Sending a message of 16 bytes
0xc486fc (CA client): CAS: nill message disconnect
0xc486fc (CA client): CAS: Connection 5 Terminated
CA client:
error on search for mpia:tvGuiderY
couldn't open mpia:tvGuiderY
CA.Client.Diagnostic..............................................
    Message: "Network connection lost"
    Severity: "Info" Context: "156.156.156.156"
  cau:
RE: Problems with CA in a WAN environment Jeff Hill
Prev: Re: problems with downloading VxWorks and Epics Ralph Lange
Next: problems with downloading EPICS Lifang Zheng
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: problems with downloading VxWorks and Epics F. Gougnaud
Next: RE: Problems with CA in a WAN environment Jeff Hill
