1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: One CA server question
To: "Ralph Lange" <[email protected]>, <[email protected]>
Cc: "EPICS Tech-Talk" <[email protected]>
Date: Tue, 7 Sep 1999 16:43:03 -0600
> -----Original Message-----
> From: Ralph Lange [mailto:[email protected]]
> Sent: Thursday, September 02, 1999 7:41 AM
> To: [email protected]
> Cc: EPICS Tech-Talk
> Subject: Re: One CA server question
> You will notice these "storms" of connection requests whenever a new CA
> server comes up, i.e. whenever any IOC reboots or any gateway process
> comes up.
You should also see that:
1) the traffic level resulting from this "storm" isn't a large
percentage of the available bandwidth.
2) peak bandwidth consumption immediately backs off to a moderate
level.
If you observe otherwise then please let me know. I do not have a system
of the same magnitude as BESY here on which to perform tests.
A known problem with the server library is that if you have two servers
on the same host then they will both send beacons, and then they will
produce a same host beacon beat pattern which confuses clients into
thinking that there is always a new server on the LAN. I will be
implementing a fix for this.
Jeff
Re: One CA server question Ralph Lange
Prev: RE: fdManager.cc question Jeff Hill
Next: RE: One CA server question and one CA server problem Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: One CA server question Ralph Lange
