1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DM Channel Popup Enhancement
To: Rolf Keitel <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 24 Aug 1999 16:57:28 -0700 (PDT)
On Tue, 24 Aug 1999, Rolf Keitel wrote:
> Are these changes synchronized with Deb or are we going down the MEDM
> path with mushrooming versions?
> 				- rolf -
If there is interest, I was hoping that the modifications would be added
to DM.  Right now it's a SLAC add on.  The source changes are on the web
page http://www.slac.stanford.edu/~ksykang/summer1999.shtml#m-m-c .
> Kenneth Kang wrote:
> > DM (opi) was enhanced to allow users to look at EPICS channel parameters
> > like the alarm limits.  Using the middle mouse button, DM allowed the user
> > to determine the channel name controlling the display object.  I've added
> > another button which takes that channel name and passes it as a
> > macro/template (C=[channel name]) to another .dl screen.  A default dl
> > screen name is hard-coded into motifChanName.c, and the environment
> > variable EPICS_DL_CH_FILE can specify an alternate file.
> > BaBar is using the ability to call another .dl screen with the channel to
> > examine a CA record's alarm limits and why there is an alarm.  We also
> > have an expert level screen which allows changes to the alarm levels (at
> > least until the IOC is rebooted.)
> > Kenneth Kang
> > A discussion of the internals and links to the code changes:
> | Rolf Keitel, TRIUMF         Tel: (604) 222-7453 |
> | Group Leader ISAC Controls  Fax: (604) 222-7307 |
> | and Electronics Development                     |
> | Vancouver, B.C., Canada                         |
Re: DM Channel Popup Enhancement Rolf Keitel
Prev: Re: DM Channel Popup Enhancement Rolf Keitel
Next: Re: DM Channel Popup Enhancement Ron Chestnut
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: DM Channel Popup Enhancement Chip Watson
