1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: dynamic INP/OUT evaluation
To: tech-talk <[email protected]>
Date: Fri, 13 Aug 1999 11:11:25 +0200
I'm writing a driver for a serial IP module (in-house) with
a VME_IO type of the INP and OUT field string:
#Cn Sm @parameter
I want to allow dynamical changes of n, m and parameter.
Do I have to make a copy of n, m & parameter and compare it
to identify changes or is there a kind of flag that the field has changed?
Is there a way to ask the database?
I think it is possible to have a special processing in record support if
a field has changed. That would be the most elegant way to my opinion.
But my driver will support roughly a dozen types of records and I don't
want to rewrite them all.
Regards
Andreas
Andreas Luedeke, Controls Group, Swiss-Light-Source, PSI
mailto:[email protected], tel:+41-(0)56-310-4002, fax:-4413
Re: dynamic INP/OUT evaluation Andrew Johnson
Prev: [no subject] Jeff Hill
Next: Re: dynamic INP/OUT evaluation Andrew Johnson
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
