1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: String PVs and the Portable CA Server.
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Jul 1999 16:03:11 -0500
Stephanie,
Thanks for the reply!
My origional attempt at getting strings to work were with aitEnumFixedString.
My memory is foggy as to why I wasn't able to get it to work then--but I didn't
get Fixed Strings to work either.  I remember finally settling on aitEnumString
because I was able to Put into the PV and get the put value into my code.  Also,
once Put, other clients could Get without problem.
What I need to do now is have my server change what a client Gets based on what
the server application is doing.  I can see the appropriate string in the scan
method for the PV, but I can't copy it into the smartGDDPointer so clients can
see it properly.  I really don't care if the PV is a aitEnumString or a
aitEnumFixedString--I just want it to be a string.  If you, or anyone else, has
a small snippet of code from the scan method which shows how to put a string
into a smartGDDPointer, I'd be a very happy man!
Thanks again!
Brian Tieman
APS
[email protected]
[email protected] wrote:
> Hi Brian -
> >I can declare a PV as type aitEnumString of length 1 and my defined
> >callback routine will get the proper "Put" string, however, I can not
> >get the "Scan" method to take a string from my process and display it in
> >the served PV.  This would be handy for reporting error strings, for
> >instance.
> In my PCAS, I use only aitEnumFixedString (and make sure I allocate enough
> room even if I don't need it) which works fine.  Luckily, most strings in
> my application are 40 chars or less - the few oddball strings that are more,
> I convert to unsigned byte arrays and let clients deal with them special
> if they care (nobody's tried to connect to these few channels so nobody's
> complained).
> I'll be interested to know if you get aitEnumString to work.  Thanks,
> Stephanie Allison
Re: String PVs and the Portable CA Server. saa
Prev: RE: channel access time response Frank Lenkszus
Next: Re: String PVs and the Portable CA Server. saa
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: String PVs and the Portable CA Server. saa
Next: RE: String PVs and the Portable CA Server. Peregrine McGehee
