1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: bug in EPICS R3.13 and R3.12
To: "EPICS-tech-talk" <[email protected]>
Date: Wed, 21 Jul 1999 18:52:49 -0600
All,
Last week during testing I found a bug in the channel
access client library which, while it should occur under
rare circumstances, is significant because it could result
in the failure of client side programs. If the problem
occurs in client programs running in the IOC experimental
evidence indicates that under heavy network communication
load network communication may stall or permanently fail.
I introduced the bug into R3.12 in August of 1995.
Symptoms on a workstation:
o client programs stall or hang when the workstation is
experiencing heavy network communication load
Symptoms on an IOC:
o dbCaLink or sequencer task in IOC is temporarily
or permanently using all available CPU at its priority
level.
o network communication to the IOC stalls or possibly
permanently fails under heavy network communication load
A patch for R3.13 will be available soon (I have committed
a fix to the R3.13.1 branch at APS). My apologies for any
inconvenience that this has caused.
Jeff
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: FW: NI VXIpc SBC and VxWorks Jeff Hill
Next: EPICS CA server and also GDD issues Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: bug in EPICS R3.13 and R3.12 Kenneth Kang
