Hi Brian -
>I can declare a PV as type aitEnumString of length 1 and my defined
>callback routine will get the proper "Put" string, however, I can not
>get the "Scan" method to take a string from my process and display it in
>the served PV. This would be handy for reporting error strings, for
>instance.
In my PCAS, I use only aitEnumFixedString (and make sure I allocate enough
room even if I don't need it) which works fine. Luckily, most strings in
my application are 40 chars or less - the few oddball strings that are more,
I convert to unsigned byte arrays and let clients deal with them special
if they care (nobody's tried to connect to these few channels so nobody's
complained).
I'll be interested to know if you get aitEnumString to work. Thanks,
Stephanie Allison
- Re: String PVs and the Portable CA Server. Brian Tieman
RE: channel access time response Jeff Hill
Re: String PVs and the Portable CA Server. john sinclair
<1999>
<1999>
