1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: String PVs and the Portable CA Server.
To: Tech Talk <[email protected]>
Date: Wed, 21 Jul 1999 11:28:52 -0500
Hey all,
Hopefully there's someone out there who can help me.  We've been using
the portable CA Server on Windows for close to a year now for several
projects.  What I did was to take the simple example program and modify
it so it had the hooks we needed to serve PVs from code we wrote to
control CCD cameras.  The one bit of functionality I have yet to be able
to get working is the proper serving of string PVs.
I can declare a PV as type aitEnumString of length 1 and my defined
callback routine will get the proper "Put" string, however, I can not
get the "Scan" method to take a string from my process and display it in
the served PV.  This would be handy for reporting error strings, for
instance.
Below is the scan method for a scalar pv declared as aitFloat32.
PVtypes is a union of all supported pvtypes.  newValue is the value from
my process which is to be "scanned" into the server and made availiable
to client through caget calls.
void exScalarPV::scanFloat32 (PVtypes *newValue)
caStatus        status;
smartGDDPointer pDD;
aitFloat32      limit;
int    gddStatus;
 pDD = new gddScalar (gddAppType_value, aitEnumFloat32);
 if (pDD==NULL) {
  return;
 // smart pointer class manages reference count after this point
 gddStatus = pDD->unreference();
 assert (!gddStatus);
 if (newValue != NULL)
  limit = (aitFloat32) this->info.getHopr();
  newValue->pvfloat32 = tsMin (newValue->pvfloat32, limit);
  limit = (aitFloat32) this->info.getLopr();
  newValue->pvfloat32 = tsMax (newValue->pvfloat32, limit);
  *pDD = newValue->pvfloat32;
  status = this->update (*pDD);
  if (status!=S_casApp_success)
   errMessage (status, "scalar scan update failed\n");
This code works fine.  When the PV is of type aitEnumString, however, I
get the correct value in newValue as a char*, but I can't figure out how
to properly scan that value into the smartGDDPointer so my clients can
see it.
If anyone has done this or knows how to do it, I'd much appreciate your
help.
Thanks!
Brian Tieman
APS
[email protected]
Re: String PVs and the Portable CA Server. john sinclair
Prev: channel access time response Dale L. Brewe
Next: RE: channel access time response Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: channel access time response Frank Lenkszus
Next: Re: String PVs and the Portable CA Server. john sinclair
