1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: writing waveform out
To: tech-talk <[email protected]>
Date: Tue, 13 Jul 1999 18:06:30 +0200
Hi all,
I need a waveform output record with variable array length.
A pretty common requirement I think, so I hope someone has already done
it.
I'm writing device/driver support for the SLS power supply controller.
The controller can download arbitrary reference current waveforms
which will be started at an external trigger.
As I understand, the 'aao' record does not support modification of the
NELM field, to tell device support how long the current array is.
I could send the data-length through the first value of the array or
through an extra longout record to the device support, but maybe someone
can tell me a more common way.
Thanks in advance
Andreas
mailto:[email protected]
Re: writing waveform out Steven M Beard
Re: writing waveform out J. Frederick Bartlett ([email protected])
Prev: Channel Access for Java Eric Boucher
Next: Re: writing waveform out Steven M Beard
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
