1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: scaler record
To: Graham Waters <[email protected]>
Date: Mon, 5 Jul 1999 22:30:47 -1000 (HST)
Had something similar happen with other record types. I found that
setting the DOL to CPP alone didn't work but had to put CPP into the
hardware input as well, e.g.:
val(in):mount:airmass CPP NMS
(this is for a UFTI DHS DTYP, probably not used anywhere else)
In our application this works.
Maren Purves
UKIRT
On Mon, 5 Jul 1999, Graham Waters wrote:
> I recently built the scaler record v3.2 with VSC16 device support.
> It basically works fine, however writing to "CNT" via a database link
> will not process passive. I can see the field change from a "dm" screen
> but nothing happens. It works fine if I use dbpf or any variety of
> dbPutField.
> Suggestions and comments welcome
> |Graham Waters, Control System Eng          Internet: [email protected]|
> |TRIUMF --- University of British Columbia,    phone: (604)-222-1047  |
> |Vancouver, BC, Canada                           Fax: (604)-222-7307  |
> |http://edevel9pc.triumf.ca/homepage/graham01.html                    |
> For every expert there is an equal and opposite expert
> 					- Arthur C Clark
scaler record Graham Waters
Prev: scaler record Graham Waters
Next: Re: pp_value in dbd file Marty Kraimer
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: scaler record Marty Kraimer
