1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS archiver
To: "Brian McAllister" <[email protected]>, "Eugene T. Yamamoto" <[email protected]>
Cc: <[email protected]>
Date: Thu, 1 Jul 1999 13:56:36 -0600
If this particular archiver code was stored at some site (hopefully APS) in
remote accessible CVS then it would be possible for knowledgeable persons to
apply patches given that the original author no longer works in the
collaboration.
> > Actually, AR does a core dump. No intentional aborts as far as
> I can see.
> > Maybe we just have a REALLY old version of AR.
> It calls assert(), which calls abort() when it fails, which generates a
> SIGABRT signal, which will cause a core dump if the current working
> directory is writable.
> See assert(3) and abort(3).
> It is quite intentional, and this isn't the only place AR dies in response
> to a condition which is not a true error condition.  Among other
> things, it
> does not distinguish between a write "failure" due to the max file size
> being exceeded and an actual error in writing to the file.
> ARR has similar problems.  For instance, if you are retrieving
> data and the
> file size has changed since the last retrieval, it aborts().  Using the
> "resync" item in the "retrieve" menu will prevent that.  If the size
> changes in the middle of the retrieve, you lose regardless.  This makes it
> harder to use on a "live" archive file than it should be.
Jeff
Re: EPICS archiver Brian McAllister
Prev: EPICS on vxWorks/x86 john sinclair
Next: RE: security windows for EPICS Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS archiver Brian McAllister
Next: EPICS training Bob Dalesio
