1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building EPICS on Linux
Date: Fri, 11 Jun 1999 10:17:44 -0500
Geoff,
We tried to fix this as problem for all host architectures by adding
the WIND_HOST_TYPE definition in the files CONFIG_HOST_ARCH.<hostarch>.
I think that the definition in the CONFIG_HOST_ARCH.Linux must be
incorrect
and you need to fix it. You need to set WIND_HOST_TYPE to the
description for Linux that you find in the tornado host
directory. On our solaris machine that directory contains the
following subdirectories -
usr/local/vw/tornado101/host :ls
include/        resource/       sun4-solaris2/  tcl/
man/            src/            sun4-sunos4/
so we put the definition WIND_HOST_TYPE = sun4-solaris2
into CONFIG_HOST_ARCH.solaris and the line WIND_HOST_TYPE = sun4-sunos4
into the CONFIG_HOST_ARCH.sun4 file.
I think you may be the first person to do an vx cross-compile on a
Linux host and the WIND_HOST_TYPE definition in CONFIG_HOST_ARCH.Linux
was never correct.
Hope this helps.
Janet
P.S. Before we found out from Rozelle Wright at LANL that setting
WIND_HOST_TYPE would fix the problem, at APS we put the following
soft link for as into the tornado directory structure and that also
solved the problem.
/usr/local/vw/tornado101/host/sun4-solaris2/lib/gcc-lib/m68k-wrs-vxworks/cygnus-2.7.2-960126
ll
drwxr-sr-x   3 vw           512 Sep  2  1997 ../
lrwxrwxrwx   1 other         67 Mar 22  1998 as ->
m68k-wrs-vxworks/bin/as*
-rwxr-xr-x   1 vw       1890436 Apr  1  1997 cc1*
-rwxr-xr-x   1 vw       1991568 Apr  1  1997 cc1obj*
-rwxr-xr-x   1 vw       2447768 Apr  1  1997 cc1plus*
-rwxr-xr-x   1 vw        116132 Apr  1  1997 cpp*
-rwxr-xr-x   1 vw         66704 Apr  1  1997 ld*
-rw-r--r--   1 vw         31424 Apr  1  1997 libgcc.a
drwxr-sr-x   3 vw           512 Sep  2  1997 m68000/
drwxr-sr-x   2 vw           512 Sep  2  1997 msoft-float/
-rw-r--r--   1 vw          3415 Apr  1  1997 specs
Geoff Savage wrote:
> We are attempting to setup an EPICS build enviroment on a PC running
> Linux.  I have run into two difficulties.
> 1. I had to add an extra -B<bin path> to GCC.  This specifies the
> location of the cross assembler, as.
> 2. The build stops with an error.
> ***No rule to make target `../../bin/mv162/vxWorks', needed by
> `buildInstall'.  Stop.
> Now the questions:
> We use gcc as for cross compiles and for host compiles.  How do I keep
> the two separate with hacking the GCC command line?
> Is there a clean way to remove the error message about vxWorks?  Do I
> have to modify the iocCore vxworks makefile?
> Thanks in advance.
> Geoff Savage
Prev: New epics list server (fwd) Ron MacKenzie
Next: Labview as a Channel Access Server Ron Chestnut
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Building EPICS on Linux William Lupton
Next: Re: Building EPICS on Linux Bill Lavender
