Subject: |
Re: "Exploding" a waveform into individual values |
Marty Kraimer <[email protected]> |
Date: |
Thu, 03 Jun 1999 08:24:33 -0500 |
Ron Chestnut wrote:
> Hello All,
> I think I've seen the answer to this, I may have even asked the question before.
> I have a 10 element waveform (type float) from which I wish to extract each
> element into an individual AI.
> I could code 10 individual subArray records, each mapped to another element, but
> a subroutine record seems easier. If my 10 element waveform VAL is linked to A
> of the subroutine record, is the code simply:
> psub->b=psub->a[0]
> psub->c=psub->a[1], etc.?
> That seems much too easy, and "a" is not an array, right?
> /Ron Chestnut
The safe way to do this is
#include "dbAccess.h"
DBADDR *pdbAddr
pdbAddr = dbGetPdbAddrFromLink(&psub->inpa);
if(!pdbAddr) { /*ERROR DO SOMETHING*/}
The DBADDR structure contains all the info you need, i.e.
typedef struct dbAddr{
struct dbCommon *precord;/* address of record */
void *pfield; /* address of field */
void *pfldDes; /* address of struct fldDes */
void *asPvt; /* Access Security Private */
long no_elements; /* number of elements (arrays) */
short field_type; /* type of database field */
short field_size; /* size (bytes) of the field being accessed */
short special; /* special processing */
short dbr_field_type; /* field type as seen by database request*/
/*DBR_STRING,...,DBR_ENUM,DBR_NOACCESS*/
}DBADDR;
In particular
pfield is the addresss of actual data
no_elements is actual size of the array
field_type is the data type, i.e. DBF_xxx
You should check that the data type is what you expect, for example
if(pdbAddr->field_type != DBF_DOUBLE|| pdbAddr->no_elements<=myindex) {
/*error */
} else {
double mydata;
double *subdata = (double *)pdbAddr->pfield;
mydata = subdata[myindex]
If the array varies in size you should also call the subroutine RSET
get_array_info routine to get the current size (note that no_elements is the
maximum size). This can be done by
struct rset *prset;
prset=dbGetRset(pdbAddr);
long *no_elements = 0;
long *offset = 0;
if(prset && (prset->get_array_info)) {
status = (*prset->get_array_info)(pdbAddr,&no_elements,&offset)
Marty Kraimer
subscribe Mathias
Controlling Beamline Magnets Mathias
<1999>
Re: "Exploding" a waveform into individual values Noboru Yamamoto
<1999>
