Subject: |
Re: mv230x floating point underflow |
[email protected] (Kevin Tsubota) |
Date: |
Tue, 11 May 1999 11:41:05 -1000 |
FYI,
I just wanted to pass on this bit of information regarding
the disabling of floating point underflow on PPC boards.
This avoids having to modify all existing tasks to set fpscr.
I loaded this at the start of my startup script and enabled it via:
taskCreateHookAdd( usrFppCreateHook )
I've also attached my version of it because it would not compile as is.
If anyone sees a problem with this please let me know...
Kevin Tsubota
California Assoc. for Research in Astronomy
(808)885-7887
----- Begin Included Message -----
>From [email protected] Mon May 10 04:28:52 1999
X-UIDL: 8ac3e91a156d7c25b9362552500b4d00
X-Mailer: Novell GroupWise 4.1
Date: Mon, 10 May 1999 09:27:52 -0500
To: [email protected]
Subject: Re: mv230x floating point underflow
Content-Length: 5401
Kevin,
vxMsrGet(), vxMsrSet(), vxFpscrGet() and vxFpscrSet() have meaning only in
the context of the current task. You need to modify the MSR and FPSCR
registers in the TCB, so that when a context switch occurs to a task, the
desired values are loaded into those registers. I have enclosed a copy of
my implementation. You should find it generic enough for your needs.
Good luck!
Charlie Grames
The Boeing Company
(314) 233-1956
[email protected]
------------------- fpscr.c follows -------------------
#include <vxWorks.h>
#include <stdio.h>
#include <vxLib.h>
#include "taskLib.h"
#include "arch/ppc/archPpc.h"
#include "arch/ppc/fppPpcLib.h"
** The following #define statements allow control over which floating-point
** conditions generate exceptions. Use FP_ENABLE_... to explicitly enable an
** exception and FP_DISABLE_... to explicilty disable it. Use #undef to use
** the default VxWorks setting for a given condtition.
** The recommended configuration enables exceptions for invalid operations,
** overflows, and division by zero, and disables exceptions for underflows and
** inexact conditions.
#define FP_ENABLE_INVALID_OPERATION_EXCEPTIONS
#define FP_ENABLE_OVERFLOW_EXCEPTIONS
#define FP_DISABLE_UNDERFLOW_EXCEPTIONS
#define FP_ENABLE_ZERO_DIVIDE_EXCEPTIONS
#define FP_DISABLE_INEXACT_EXCEPTIONS
** The following #define statement allows control over the floating-point
** non-IEEE mode. In non-IEEE mode, denormalized numbers, NaNs, and some IEEE
** invalid operations are treated in a non-IEEE conforming manner. Refer to
** the PowerPC 604 RISC Microprocessor User's Manual for details. Use
** FP_ENABLE_... to explicitly enable non-IEEE mode and FP_DISABLE_... to
** explicitly disable it. Use #undef to use the default VxWorks setting.
** The recommended configuration disables non-IEEE mode (i.e., all floating-
** point operations are IEEE compliant). Use of non-IEEE mode causes
** denormalized operands and results to become zero, which may be desirable
** for code ported from platforms using DEC proprietary floating-point
** formats.
#define FP_DISABLE_NON_IEEE_MODE
** The following #define statement defines precise mode for floating-point
** exceptions. In this mode, the system floating-point enabled exception
** handler is invoked precisely at the instruction that caused the exception.
** Use #define to enable this mode and #undef to disable it. Note that
** precise mode will not be set if no floating-point exceptions are enabled.
** The recommended configuration disables precise mode. Precise mode may
** degrade performance and should be used only for debugging.
#undef FP_PRECISE_MODE
/*#ifdef INCLUDE_HW_FP */
* usrFppCreateHook - modify floating-point environment for a newly-created task
* This routine modifies the default VxWorks floating-point environment for a
* newly-created task. Floating-point exceptions are explicitly disabled for
* tasks created without floating-point support. The floating-point environment
* is established as specified by the user for tasks created with floating-point
* support. usrFppCreateHook is installed as a task create hook and is called
* indirectly whenever a new task is created.
* RETURNS: N/A
void usrFppCreateHook(FAST WIND_TCB *pTcb)
#if (CPU_FAMILY == PPC)
int fpcsr; /* floating-point status and control register, alias fpscr */
int fpcsrOld=0;
** If floating-point operations are not enabled for this task, set the FE bits
** to ignore floating-point exceptions, and return.
if (!(pTcb->options & VX_FP_TASK))
pTcb->regs.msr &= ~(_PPC_MSR_FE0 | _PPC_MSR_FE1);
return;
** Modify the the floating-point status and control register in the floating-
** point context of the new task.
fpcsr = (int)(FP_CONTEXT *)(pTcb->pFpContext)->fpcsr;
fpcsrOld = fpcsr;
#if defined(FP_ENABLE_INVALID_OPERATION_EXCEPTIONS)
fpcsr |= _PPC_FPSCR_VE;
#elif defined(FP_DISABLE_INVALID_OPERATION_EXCEPTIONS)
fpcsr &= ~_PPC_FPSCR_VE;
#endif
#if defined(FP_ENABLE_OVERFLOW_EXCEPTIONS)
fpcsr |= _PPC_FPSCR_OE;
#elif defined(FP_DISABLE_OVERFLOW_EXCEPTIONS)
fpcsr &= ~_PPC_FPSCR_OE;
#endif
#if defined(FP_ENABLE_UNDERFLOW_EXCEPTIONS)
fpcsr |= _PPC_FPSCR_UE;
#elif defined(FP_DISABLE_UNDERFLOW_EXCEPTIONS)
fpcsr &= ~_PPC_FPSCR_UE;
#endif
#if defined(FP_ENABLE_ZERO_DIVIDE_EXCEPTIONS)
fpcsr |= _PPC_FPSCR_ZE;
#elif defined(FP_DISABLE_ZERO_DIVIDE_EXCEPTIONS)
fpcsr &= ~_PPC_FPSCR_ZE;
#endif
#if defined(FP_ENABLE_INEXACT_EXCEPTIONS)
fpcsr |= _PPC_FPSCR_XE;
#elif defined(FP_DISABLE_INEXACT_EXCEPTIONS)
fpcsr &= ~_PPC_FPSCR_XE;
#endif
#if defined(FP_ENABLE_NON_IEEE_MODE)
fpcsr |= _PPC_FPSCR_NI;
#elif defined(FP_DISABLE_NON_IEEE_MODE)
fpcsr &= ~_PPC_FPSCR_NI;
#endif
pTcb->pFpContext->fpcsr = fpcsr;
** Modify the machine status register (MSR) in the context of the new task.
** If no floating-point exceptions are enabled, set the FE bits to ignore
** floating-point exceptions. Otherwise, set precise mode, if defined above,
** or imprecise nonrecoverable mode.
if (!(fpcsr & (_PPC_FPSCR_VE | _PPC_FPSCR_OE | _PPC_FPSCR_UE |
_PPC_FPSCR_ZE | _PPC_FPSCR_XE)))
else
#ifdef FP_PRECISE_MODE
pTcb->regs.msr |= _PPC_MSR_FE0 | _PPC_MSR_FE1;
#else
pTcb->regs.msr = (pTcb->regs.msr & ~_PPC_MSR_FE0) | _PPC_MSR_FE1;
#endif
#endif /* CPU_FAMILY == PPC */
/* #endif */ /* INCLUDE_HW_FP */
EPICS Channel Access Michael J. Feldhake
CAEN HV Burkhard W. Kolb
<1999>
14 or 16 bit IO boards Garrett D. Rinehart
<1999>
