1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA @ the SSTF in St. Louis MO
Date: Fri, 30 Apr 99 10:09:39 EDT
Gentlemen,
	I am happy to inform you that there is another functional CA Client
running at Boeing's Subsonic Testing facility in St. Louis.  Unfortunately,
the functional part is short lived - after about 10-15 minutes, the CA
Client Diagnostics receives messages from the Server that it is unable to
'Allocate Additional Memory' for cell.....(See Attached screen dump bitmap
for the complete message).  The DAQ Crate must be re-booted before the
Channel Access port will respond again - all other activity appears to
remain active in the crate from other accessible nodes (i.e. UNIX Clients).
	Can you provide us some assistance on this issue.  I hope it's no more
than an incompatible driver issue with the Client using the later libraries
from EPICS and the DAQ using older ones ?
Mike
Prev: Re: Looking for EPICS edd 1.16 built for Solaris Everett Harvey
Next: C++ development on IRIX hosts Peregrine McGehee
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Allen Bradley Support Marty Kraimer
Next: RE: CA @ the SSTF in St. Louis MO Jeff Hill
