1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: possible bug in et_wish R3.12.2
Date: Wed, 21 Apr 1999 17:22:04 +0100
Dear all,
I think there's bug in et_wish / R3.12.2 :
using asynchronous links, the data structures are not correctly
allocated.
After successfull connection, the handler use argument of type
DBR_STS/DBR_CTRL to retrieve initial values, and subsequently allocate
memory using these types.
The monitor/get operations work on DBR_TIME, hence it screws up.
I run a simple test monitoring strings where we allocate 44 bytes rather
than the expected 52 for DBR_TIME_STRING.
here's my suggested fix (tclCa.c):
* whenever async cntl data is received...retrieve info buffer
void updateChCtrl(struct event_handler_args args) {
  CHANDATA *pch;
  INFOBUF *pinfo;
  int nBytes;
  int status;
  pch = (CHANDATA *)args.usr;
  nBytes = dbr_size_n(args.type,args.count);
  pinfo = &pch->info;
  memcpy((char *)pinfo, args.dbr, (size_t)nBytes);
  modified by mdcb 990421: at this stage - args is still a DBR_STS or
DBR_CTRL
  pch->initSize = nBytes;
  /* we actually want DBR_TIME */
  pch->initSize =
dbr_size_n(dbf_type_to_DBR_TIME(pch->iType),args.count);
  /* now does calloc ... */
  updateLink(pch);
PS: I posted a mail few times ago to try and find out who was looking
after et_wish, is this package still supported ?
Cheers,
  Matthieu
Matthieu Bec                       Isaac Newton Group
tel  : +34 922 425427              Apartado de Correos 321
fax  : +34 922 425401              38780 Santa Cruz de La Palma
url  : www.ing.iac.es/~mdcb        Canary Islands, Spain
Prev: training Bob Dalesio
Next: hyphens in ca access security hostnames Carl Lionberger
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
