1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: g++ and libCom/fdManager.cc
To: [email protected] (EPICS Tech-Talk)
Date: Tue, 13 Apr 1999 17:44:07 +0200 (METDST)
> Recently I installed gcc-2.8.1 into our HP-UX10.2 machine together with
> g++. When I tried to build epics3.13/base with gcc/g++
Which version of base? (The c++-sources have changed a _lot_ lately.)
> Does anyone know if it is possible to compile EPICS with gcc/g++?
The c++ parts of EPICS base are not (yet) mandatory. So you don't need a
c++ compiler at all to compile and run EPICS. (Sorry if this is too obvious.)
Apart from that: Yes.
I.e. I know it _and_ it's possible.
While HP's native c++ compiler (and the CenterLine compiler) do not compile
the c++ parts, g++ manages to build things.
I'm using gcc 2.7.2.3 on a HPUX 10.20 machine and EPICS Base 3.13.1
(fdManager.cc v 1.15).
Ralph
g++ and libCom/fdManager.cc Noboru Yamamoto
Prev: g++ and libCom/fdManager.cc Noboru Yamamoto
Next: Channel access server on a VxWorks (non-EPICS) IOC? John A. Priller
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
