Chris Timossi will likely comment further re NT specifics, but just to
give a reference point, these functions make 7,000 successful connections
in something less than 2 seconds from Unix on an old Sparc 2. It is
important to queue all the requests before processing them, do not do
them one at a time. (ie queue everything then one do_get). The
interfaces in the underlying Channel Access are significantly optimized
for batch processing and SCA uses this. In addition, single requests
cause a flurry of packets on the network that can cause tinygrams to
impact network performance for hosts and network neighbors without
getting much work done.
That having been said, 250-300 msec sounds slow even for individual
requests. Possibly a configuration problem.
-- Alan K Biocca
At 09:51 AM 4/9/99 -0500, Dale L. Brewe wrote:
I've been using the Simple Channel Access
libraries under NT, and have
noticed that the time to make an initial connection is quite long.
For
example, using the routine cache_getbyname, it takes about 45sec to get
140
values initially (~0.33sec/value). I've also tried the batch
routines
que_get and do_get, with a marginal improvement (to ~0.25sec/value),
which
is still pretty difficult to live with. Can anyone tell me if they have
a
similar experience? Is this an inherent limitation of these
functions/library, or is it possible to improve the performance? My
ioc
uses epics 3.13beta11 and my client (based on LabVIEW) has used
sca3.dll
and ca.dll for 3.13.0 and previous versions.
Thanks
Dale Brewe
Dale L. Brewe PNC-CAT/U. of
Washington
ph: 630 252 0582
fax: 630 252 0580
Mail:
APS/Argonne National Laboratory
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
- Re: Slow initial connection using Simple Channel Access Dale L. Brewe
- Slow initial connection using Simple Channel Access Dale L. Brewe
<1999>
<1999>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
