Werner,
I haven't seen any responses to this, so I'll jump in!
You wrote:
>During initialization I get the error message that _excStub and
>_excIntStub are not in the symbol table.
>With the mv167 board these two symbols are defined in vxWorks.
>In the case of the mv2306 these two symbols (and perhaps others, too)
>are not defined in vxWorks.
Right. The errors come from within devLib but are in fact only warnings.
The code is following the list
{"excStub", "excIntStub", "unsolicitedHandlerEPICS"}
looking for an existing entry point. On the Power PC, it doesn't find the
first two but does find the last. I think (Jeff Hill might care to comment)
that it would be fine simply not to search for the first two on the Power PC.
>Because of the different architecture there might be other functions.
>But, how are they called?
>Has somebody modified a driver for the mv2306 board?
>Has somebody experience with interrupt handling on a mv2306 board?
We are using mv2303 and mv2307 boards (the mv2306 is just a mv2307 with
less memory, right?). We don't yet have much experience with device
access but are actively working on porting our control systems from
M680x0 boards. I don't think we expect properly-written drivers to need
changes when moving between architectures. Kevin Tsubota
([email protected]) is doing this work and you might want to
contact him directly.
William
--------------- William Lupton ([email protected]) ---------------
Home: PO Box 7135, Work: W. M. Keck Observatory, 65-1120 Mama-
Kamuela, HI 96743, USA lahoa Highway, Kamuela, HI 96743, USA
(808) 885 3475 (808) 885 7887, (808) 885 4464 (fax)
problems with OMS motor controller and power pc cpu board mv2306 Werner Portmann
RE: problems with OMS motor controller and power pc cpu board mv2306 Jeff Hill
<1999>
<1999>
