Jennifer Dunn wrote:
> Hi,
> I am creating a custom record, and have defined a field in the record to
> have special processing at run time (special = SPC_MOD) and have the pp_value
> set to YES (a passive record should be processed when Channel Access writes
> to this field).
> In the record support code I have a routine called special, that simple sets
> a flag to indicate that the record was accessed - and then expect that
> after special the "process" routine should be called.
process is not called as a result of a put to a special field.
If you want the record processed then, after the second call to special, call
scanOnce.
Marty Kraimer
- Record support question Jennifer Dunn
Turbo PMAC and PMAC-2 cards / MACRO interface Martí Pi
Re: Record support question Tim Mooney
<1999>
Re: Record support question Benjamin Franksen
<1999>
